1989 Ford Bronco No Spark
Alrighty fellas,
trying to get this bronco that we just purchased started has the 4.9 L6 in it with the 5 speed trans. Replaced the fuel pumps (both high and low pressure), replaced the clutch, replaced the master brake cylinder, the master clutch cylinder, slave cylinder, new clutch kit, and new starter solenoid.
Car will turn over but wont start. Lead to believe that there is no spark. Also after a while the fuel pump sounded like it wasnt kicking in. Does that mean the fuel pump is already pressurized? Or is my relay bad? Also the ignition coil is getting 12 volts to it so I dont think that is going bad. Any help?
If the PIP is sending a signal to the ICM and the ICM is pulsing with no spark then try disconnecting the computer (PCM ).
figured it out. If you take the PIP out, and take an ohmmeter to it, you can test it to factory spec, if not, then its a bad PIP. Replaced that and ended up needing to replace the ignition coil as well. Now it starts up but has a rough idle, will speed up and slow down, even stall. Tried cleaning the EGR, which seemed to help a little but then kept doing the same thing. Also the clutch seems to not disengage correctly. You can see my issue in the other thred just recently posted.
lars of colorado
12-08-2010 09:48 AM
93E-150
03-29-2010 05:26 PM
F2501988
05-13-2004 10:05 AM
