blower almost sucks
Old 07-23-2015, 12:37 PM
bcaughhorn's Avatar
bcaughhorn
bcaughhorn is offline
blower almost sucks
Does anybody make a blower that moves more air? My A/c is cold but doesn't blow good. I can feel it in the front seat but not good. It has been changed before by the po.
Old 07-23-2015, 01:37 PM
coax9952's Avatar
coax9952
coax9952 is offline
Your Ducting under the dash is probably got big holes in it.... nothing lasts forever, or you may have a vacuum leak at your ESOF pump system causing your AC/Defrost louvers to hang up. I replaced mine (Pump) to fix my 4x4 switching problem and my OEM Blower works almost too good now. That pump runs the whole vacuum system.
Old 07-23-2015, 02:09 PM
carltonwebb's Avatar
carltonwebb
carltonwebb is offline
It may be that the evaporator coil is pretty dirty. If you buy the coil cleaner in the can at the hardware store, remove the blower motor, and give it a good spray like the can says. It will make a big difference.
If you get it first thing before the a/c has been run that day, an air blower through the blower motor hole may help as well.
Old 07-23-2015, 08:50 PM
bcaughhorn's Avatar
bcaughhorn
I checked the defrost and floor vents. It's only blowing from the vents
Old 07-23-2015, 08:51 PM
bcaughhorn's Avatar
bcaughhorn
I reckon I'll pick some up tomorrow and try that out Saturday
Old 07-23-2015, 08:57 PM
carltonwebb
I will warn you and say its aggravating to get it sprayed in there. I like the can stuff b/c its self foaming and will push the buildup out of the fins.
Old 07-23-2015, 09:42 PM
bcaughhorn's Avatar
bcaughhorn
Ok. Thanks. Its worth a shot
Old 07-28-2015, 01:17 PM
bcaughhorn's Avatar
bcaughhorn
You sir are right on the money. Is it possible to take the housing off and clean it good or is that done from under the dash?
Old 07-28-2015, 05:02 PM
petrokiller's Avatar
petrokiller
petrokiller is offline
Spray the cleaner then use just open end garden hose and flush the fins. MAKE SURE that the evaporator drain isn't clogged first. You may flood your truck.
Anything and everything that falls into the grill under windshield can end up clogging the evaporator. I found nuts pine needles and other goodies in my previous OBS truck.
Oh yeah I used shop vac reduced down to a piece of garden hose to get in the corners and vac the loose crap out first. Good Luck.
Old 07-28-2015, 09:45 PM
JockD's Avatar
JockD
JockD is offline
Since the prior owner replaced the blower motor, there is another thing to check. If you remove the blower to clean the evaporator, check the rotation of the blower motor. If the motor is turning the wrong direction, the fan will not move much air.
I have experienced replacement blower motors that had the color code for the wires exactly backwards from stock. This made the motor run backwards if you matched the colored wires. I had to reverse the wires to get the blower to run the right direction.
Old 07-28-2015, 11:07 PM
bcaughhorn's Avatar
bcaughhorn
That did cross my mind earlier. But I did not look into it yet.
Old 07-29-2015, 09:56 AM
kbarbee95's Avatar
kbarbee95
kbarbee95 is offline
Does the fan speed change with all adjustment settings? I say this because my truck would only get to the third setting and when I turned it up to the 4th setting it wouldnt change. I replaced a small resistor/switch or something that is screwed in to between the evap coils and blower motor. It has 2 screws and red plastic that over time the contacts in there rust and corrode and you lose the fan speeds. I had to completely break mine and wire it up because it was so stuck and brittle it wouldn't come off
Old 07-29-2015, 11:16 AM
bcaughhorn's Avatar
bcaughhorn
I changed it already. And had the same problem
cwnitsuj
2004 - 2008 F150
08-07-2013 07:19 AM
MMG
1999 to 2016 Super Duty
06-19-2013 05:38 PM
jmart08
03-02-2011 08:34 PM
sixing
Electrical Systems/Wiring
11-28-2010 08:31 AM
Quick Reply: blower almost sucks
