Gas tank float ?
Gas tank float ?
No wonder the gas gauge didn't work . One of the only things I thought couldn't be screwed up but the PO did it ! PO must have been short on $$ .All though it did happen & required a new sending unit , time & $$ I do find it quite humorous . Will replace the in line filter as it has some cork/ wood particles in it . Go figure .This has got to take the cake as one of the most offending PO fixes ..
Well this sender didn't cure the problem .Still reads full when it is only 1/2 full now . Removed the cork & oak stopper , attached the brass float from the new one to the old sender installed & it still reads full . Made sure the sender was grounded . Nothing different . Damn. This thing is kicking my a$$ like the starter was . After reading some previous info on here & the ford barn I thought attaching the brass float to the old sender would have cured the problem since it has the correct ohm range . .
The thermal nature of these gauges makes them susceptible to failure. Your gauge may just be bad.
You can adjust the gauge a certain amount by way of an adjuster visible thru a hole in the back of the gauge. May help enough.
PS -- make sure your gauge panel is adequately grounded. With all that red paint it may not be.
If it was me, Id start here....disconnect the sending unit wire and with key on touch the bare end of the wire to an unpainted surface on the fuel tank. Gauge should read full grounded to the tank, empty unplugged. If it doesnt read full grounded to the tank, check your tank ground by connecting the sending unit wire to your battery negitave terminal with a jumper wire of some sort. It should then read full. If it does read full after grounding it to your battery and not to your fuel tank, you know the wiring is good to the gauge and your tank ground needs to be addressed.
If after that the gauge still doesn't function correct full grounded/ empty open then move the testing closer to the gauge. If the same test still don't move the needle correctly you now know the gauge is bad, or your float rod just needs to be adjusted.
Looks like an LMC sending unit. bought one myself. What junk, even if the ohms were correct the sending unit went from like 0 ohms empty, 7ohms 1/2 and back to 0 full... ended up putting the new float on the old sending unit and used it.
oft
16
12-26-2014 09:08 PM
lilbilli0naire
12-07-2008 09:28 AM
