Soldering solid strand wire that supplies IVR
Old 07-18-2015, 05:26 PM
SixGunCaliforniaKid's Avatar
SixGunCaliforniaKid
SixGunCaliforniaKid is offline
Can't get this F'ing this soldered, tried extra flux, diff solder, sanding, torch, low heat iron, high heat iron, everything I can think of.
What the heck is this wire made of? Aluminum?
A crimp connector is out of the question, I have soldered and heat shrinked every wire that needed it on this truck and has ZERO crimp connectors... not starting now.
Any advice tips helps, if not I guess I'm rewiring with copper...
Old 07-18-2015, 05:33 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Might be. A pic would be interesting.
Old 07-18-2015, 05:39 PM
SixGunCaliforniaKid
Old 07-18-2015, 05:57 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Huh. You've tried scraping down to bare copper and using paste flux? It doesn't look like copper does it.
Old 07-18-2015, 06:06 PM
SixGunCaliforniaKid
The wire isnt copper its silver in color and I did try rosin flux, dont have any paste.
Old 07-18-2015, 06:27 PM
redroad's Avatar
redroad
redroad is offline
If it is in fact silver it will require a higher temp ..
7459 Wahl | Mouser
Old 07-18-2015, 06:37 PM
SixGunCaliforniaKid
Didnt act like silver when I torched it LOL and its not very malleable like silver is. Would they really put 3 feet of silver wire in our trucks?
Old 07-18-2015, 06:44 PM
redroad's Avatar
redroad
redroad is offline
I think the best way is to do a fresh cut on one of the stripped wires and check the cross cut with a magnifying glass .. You will have to get down to bare copper if its copper core in order for it to solder ..
https://www.anixter.com/content/dam/...-W&C-EN-US.pdf
Old 07-18-2015, 06:56 PM
SixGunCaliforniaKid
No dice, I re cut, looked and stripped the wire in half still silver in color and tried to solder with no luck either...
Any ideas? Im about to pull out a welding rod see if I can braze it.
Old 07-18-2015, 07:07 PM
redroad's Avatar
redroad
redroad is offline
I think I would wire nut it and check if it fixed the problem before going to that extreme
Old 07-18-2015, 07:15 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Aluminum (doubtful they are using silver) is tough to solder because it instantly forms an invisible layer of corrosion upon exposure to air. Scratching/scraping the material through a blob of molten solder will do the trick sometimes but there's probably a better method for what you're trying to do here.
Old 07-18-2015, 07:20 PM
SixGunCaliforniaKid
That sounds like what is exactly happening the wire is turning gray before the flux browns out. Well think I might have to nut or crimp it.... cant find any of my softer welding rods to braze it but if I could I can braze to where it works like solder, not too extreme. Thanks for the help!
Old 07-18-2015, 07:30 PM
redroad's Avatar
redroad
redroad is offline
These are my new go to for automotive wiring .. crimpandsolder They require their crimper though ..
Old 07-18-2015, 07:40 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
A non-insulated butt connector and heat shrink would take care of it.
Old 07-18-2015, 09:18 PM
winginit's Avatar
winginit
winginit is offline
use a little butane torch u got to get it hot baby! use 60-40 rosin -core solder no flux needed.
Quick Reply: Soldering solid strand wire that supplies IVR
