UVCH / IDM................. Question
Old 07-17-2015, 01:05 PM
Buck Dharma Fan's Avatar
Buck Dharma Fan
Buck Dharma Fan is offline
My truck had been running rough & losing power. My suspicion was the UVCH, and I figured I'd get to it sooner or later. I was over due for inspection so I brought it in to a shop that I deal with and asked him to scan it for me, regarding this issue. He pulled a code for the IDM and CPS. Just curious if the UVCH would make the IDM throw a code? The motor has at one time or another shut down a bank and given a CEL. Only lasted a few minutes at a time. I do have an autozone crap CPS in there still. Any feed back would be much appreciated.
Thanks Vinny
Old 07-17-2015, 01:13 PM
Hussler's Avatar
Hussler
Hussler is offline
Yes, UVCH can cause the IDM to shut down banks and that would throw a code. Did he give you the code? Best to get Ford or International CPS and be done with it.
Old 07-17-2015, 01:21 PM
dieselhead1052's Avatar
dieselhead1052
dieselhead1052 is offline
My IDM went bad last year. The truck would lose 75% of its power while in flight and when at idle the motor would lope really hard and shut off if I didn't press the accelerator. If I tried to move in reverse it'd kill the motor. That's the extent of my experience with that.
As far as the CPS goes, I keep and extra in my glove box. I've read on other threads that the CPS you want is the most current supersession of the original Ford part.
Old 07-17-2015, 03:09 PM
madpogue's Avatar
madpogue
madpogue is offline
What were the CODES?
Old 07-20-2015, 07:52 AM
Buck Dharma Fan
Thanks, yes he did give me the codes. They're written down on the receipt. Also got a code for # 2 injector.
Old 07-20-2015, 07:55 AM
Buck Dharma Fan
Thanks Madpogue............... i'll look at receipts when i get home
Old 07-21-2015, 06:41 AM
fordman67's Avatar
fordman67
fordman67 is offline
If it were me I would get a good cps in it.then ohm the valve cover connections and see if there is a problem.that will narrow it down to one side or the other.if those are OK then do you have anyone you can try your idm in their truck to confirm or deny it as a problem?
I did all that last week on a buddies truck.I thought for sure his vc gaskets were suspect.it turned out to be his idm.
Old 07-21-2015, 08:48 AM
Buck Dharma Fan
Hey Fordman, thanks I'll do that ASAP. I lost the damn receipt where the codes were written though. Yeah, the right cps is a must. The only friend i have with a 7.3.............. is a 2002 excursion. I know the idm is not so convenient to get to on that. also is it the same ?
I was thinking that I would replace the cps and have him re- scan it. This garage I use is under contract with the school dist I work for. They'll do me the favor.
Old 07-21-2015, 05:45 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
The idm's are similar. The 02 will be higher voltage. A bit of an upgrade for these ol work trucks
Old 07-22-2015, 05:53 AM
Buck Dharma Fan
Ok, with that....................... I'm guessing that they can't be swapped (borrowed) ?
Old 07-22-2015, 06:04 AM
fordman67's Avatar
fordman67
It will work just fine! It may actually work better lol
Old 07-23-2015, 10:40 AM
Buck Dharma Fan
Is it easy to get to on the 2002 ? I think its in the fender well............. right?
Old 07-23-2015, 10:43 AM
Buck Dharma Fan
Oh BTW Fordman........................ If that red one in your sig, is the same white one..................... WOW ! looks awesome
Old 07-23-2015, 01:34 PM
farmert's Avatar
farmert
farmert is offline
Yes, the IDM is in the drivers side fender well on the superdutys. The fender liner needs to be removed to get to the IDM.
Old 07-23-2015, 05:29 PM
fordman67's Avatar
fordman67
Thanks,its just the same one for 3years.
Quick Reply: UVCH / IDM................. Question
