No power, then found this???
So I had an issue with no power. Wouldn't start. No lights on dash. Replaced batteries and alternator. Nothing. So poking around I found what's in the images below. Looks like part of a harness that goes under driver side battery and also goes under cab to the trans area. Hope this isn't going to break the bank.
Seperated. Located behind driver side battery. Looks like part of a harness that goes under cab to trans
[QUOTE=tk1325;15507310]Suggestions on what I should use to clean that? Where would I get the new connection[/QUOTE
If you have the skills, you can use stuff from West Marine and build your own setup.
If not, I would look for an OEM junction block and fusible links for the easiest fix. Crimp on new terminals and go.
Once the corrosion is as bad as yours, cleaning the parts may not be the best answer, since the rust will keep going and so much material is gone...
The thread Mike linked to was mine. If you watch the video, you can see the little box wasn't replaced. Al the wires were stripped clean and spliced together. That little box is there for assembly purposes. The stud that holds the box to the fender well allows a path for corrosion to get into the connection.
I was actually lucky. I was en route to pick up a car trailer when mine went. 20 minutes later I would have gone dark going 65mph with a loaded car trailer in tow.
GREAT JOB! Thanks again...
