Fuel Line Replacement
So I have an interesting problem, I just got my truck running (1996 Ford F-150 XLT Ext. Cab) and I'm running brake lines. So far I've got the line from the master brake cylinder all the way back to the area in which the line should go. I assume the previous owner broke the brake line off rather than taking it off properly. There's still a bit of screw with a nut on it which I cant for the life of me get off. I'm thinking about taking the bed off so I can get better access to it because currently you have to have your head between the axle, muffler, and front fuel tank to get some form of access to it. Any help would be greatly appreciated.
I try to give attention to posts with zero or inadequate responses but yours is a little confusing. If you have routing questions and an existing line is there it sounds like you need to take some things off. If you physically cannot get to where you need to to mimic the route thats there, please expand. Reviving old vehicles is not for the lazy ( i am not call in you lazy). I am not trying to be condescending but please be specific in exactly what you are trying to remove if there are issues. You may want to clarify the whole "fuel line issue" then starting to talk about break line. Either way, I know some guys on here are using an online translator so I don't judge. The common interest is Ford trucks!
Edit: Oh dear, I said fuel line in the title :$ Whoops
Brake Lines
The brake lines should run from the vent tube, along the axle to the back of each wheel and to the wheel cylinders. The lines may be clipped or fastened to the axle and removed by simply manipulating the line. This will be a lot easier once you unscrew the line from the wheel cylinder.
Removing the bed will make this process a lot easier, but it's not for the faint of heart. It's not a difficult task, but plan on checking a few other items while the bed is off the truck. My fuel tanks were ready for replacement along with brake lines and fuel strainers. (Fuel pumps and valves are notorious for going bad on this vintage, too.) If there is a lot of rust on the frame and other components, this is the time to grind it off and repaint the steel. The bed bolts will probably snap off along with a few other fasteners. You'll need three other friends or a pulley system to lift the bed from the frame. Once you have the bed off the truck, you may find a few other projects.
Brake Lines
Removing the brake lines from the wheel cylinder is best done with a line wrench. However, based on the difficulty you're having, it may be best to start with new or rebuilt wheel cylinders. As I said in the previous post, plan on bolts and other fasteners to break. PB Blaster and heat from a propane or MAPP gas torch will help you along the way. (Take care when using a torch in and around gas tanks.) What kind of experience do you have working on vehicles? It will help to know your level of expertise when advising you on particular jobs and/or tools.
farmnaggie
09-23-2014 08:36 PM
bigal53021
02-20-2014 07:05 AM
Moe Craig
23
05-22-2012 12:01 AM
