2004 5.4 SD Sparkplugs
Old 07-14-2015, 12:30 PM
cub682's Avatar
cub682
cub682 is offline
I am trying to verify the type of sparkplugs used in my engine. 2004 F250 SD built Oct 2003. Does my engine have the normal plugs or the type that tend to break when removing? Also would I have the improved head with more threads for the plugs? Would also like advice on the best plugs, coils and boots to use. This truck still has original plugs and coils in it. Thanks.
Old 07-14-2015, 02:03 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Go to Official Ford Parts Site | Buy Motorcraft & OEM Ford Parts Online | FordParts.com and search for the current part number by your VIN. That's going to be the most accurate way of finding the current recommendation for spark plugs.
Old 07-14-2015, 02:58 PM
cub682's Avatar
cub682
cub682 is offline
Thanks for that link, it identified my truck to the t. Looks like I have the normal plugs. I was hoping to replace all coils at the same time but $75 each might be overkill. I think I have a bad coil and need to identify which one is bad first. Thanks again!
Old 11-12-2015, 08:36 AM
shanerus's Avatar
shanerus
shanerus is offline
I replaced plugs in 04 5.4 SD with autolite ap103 and was a mistake. They caused overheating issues because the heat range was too high even though they are rated for that engine. Motorcraft have much lower heat range and work best for triton engines. If you want something other than Motorcraft look at heat ranges on the plug you want before you buy to avoid some of the trouble I went through. I sprayed lubricant down cylinder holes and set before removal, then used anti seize on new plugs and didn't have any issues either way.
tssngs75
1999 to 2016 Super Duty
11-19-2014 04:28 AM
beth_o87
04-14-2011 02:56 PM
bradplock
1997-2006 Expedition & Navigator
07-12-2008 09:58 AM
5.4XLT
Modular V8 (4.6L, 5.4L)
10-07-2007 11:12 PM
zorba
03-06-2007 01:05 AM
Quick Reply: 2004 5.4 SD Sparkplugs
