8.8 explorer differential offset
The tranny and diff does not need to line up from above, in fact it is better for U joint bearings if they don't. Just install engine tranny centerline parallel to frame centerline (it can be centered or offset to either side as needed, many OEM installs are offset), do not angle, the drive shaft can angle between tranny-rear axle no problem. Read my headers, motormounts and crossmember topic, we offset Gary's 4.6 motor and tranny 1" to pass side for header/steering box clearance.
Mcjr, a mustang rear would be way too narrow.
hail destroyer
02-15-2018 06:06 PM
old_blue1
09-26-2014 09:06 PM
F100man
12-10-2004 05:41 AM
