262-6 valvetrain parts
Anybody know if 223 and 262 rocker arm parts are the same? I need rocker arms and the shaft/tube they mount on for my 63? 262.
DC lists 6 cyl rocker arms, plus I have a couple of 223 parts engines that may have a usable shaft. Just need to know if they interchange?
Thanks!
Thanks!
Crop duster, thanks for the info! I pulled the rockers from one of my 223's but they are kinda used up too.
Bonus question; which oil tube is supposed to feed the rocker shaft, front or back?
Someone has jury rigged mine with a single line from the rear with copper tubing and fittings. Lots of oil everywhere, but not sure it is working right.
on the 223 Rear tube takes oil from the galley and fills the rocker tube which distributes to the rockers and then pushes oil back down the front tube into the pan. Be careful of any rocker tube you get. I got two that were mis-drilled before I finally got a right one.
I noticed the 223 uses different length adjuster screws in the rockers too.....will have to swap those also.
Thanks. I'm gonna try to use the 1961/64 223/262 shaft and 1956/64 223/262 rockers....will double check the oil feed holes.
Hope to use the 1961/64 223/262 oil tubes as well.
1956/64 223/272/292 Passenger Car & Truck / 1961/64 262 Truck.
jimcar-9
05-27-2008 01:11 PM
jimcar-9
05-22-2008 11:40 AM
CN Spots
03-26-2007 01:05 PM
