A/c system issue and identification
Let me start by saying I have done my research and have not found anything that is useful. So here it goes...
I have a 1989 f-150 xt 5.0L 4x4 with a 4speed manual trans. I am working on converting my r12 system to 134. I got the adapter kit and installed the high and low fittings. I work at a shop and have r12 and 134 a/c machines that I am using for the conversion.
The issue I'm having is the line from my pump (sd-709 p/n) to the condenser is leaking. I have been searching for a week now trying to find the right line and have had no luck. I believe I have a dealer installed system. And I also think someone has jerry rigged the system before me since the lines are hose clamped on.
I am looking for a definitive way to determine which a/c system is installed in my truck. Every parts store/catalog I try to use only give me the lines for the other type of pump (fs10).
Any help is greatly appreciated. I hope someone on here is familiar with the systems and is able to point me in the right direction!
Dirt racer - That's a good idea. I was just really hoping to find some oem parts for it. Although your right a custom line will probably be cheaper, and also better quality.
Da_Lariat_Chariot- that's interesting because mine looks more like the factory installed drier. I will take a pictur tomorrow to post.
UPDATE: I did find an image of one other F-series truck with the same style a/c system. But it did not help with finding the line.
I ended up removing the line that was leaking and found that it was split at the end about 2 inches down the center on the inside. I cut it and reinstalled. Charged the system with 134a and it's been mighty cold ever since.
I used dye in the oil and have been checking for leaks. ALL THE LINES LOOK GREAT! I found the compressor to be leaking from the front case cover. I'm not to worried about that though. I'll grab a new compressor next week.
Thanks for the help.
granny_rocket
27
07-06-2014 12:49 PM
thesprocket26
11-04-2005 03:54 AM
