e4od lost gears HELP
Old 07-09-2015, 08:21 AM
Dflynn926's Avatar
Dflynn926
Dflynn926 is offline
HELPPPPP!!!!
(1995 F250 7.3 Powerstroke, 4x4, no mods, 180k miles)
I was on my way to pick up a load of wood, and when I went to back the truck up to load it, reverse just was not there, I still had drive. Then on my way home, it would not shift into 3rd or OD.
I bought the truck from a friend and he had the trans rebuilt about 4k miles ago maybe 5k, but not long enough to reason it blowing up again.
I was able to get it onto my trailer to take in, but if I could fix it myself that would be amazing.
any info would be greatly appreciated.
Old 07-09-2015, 08:30 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
Is the of light flashing?
Old 07-09-2015, 08:31 AM
sean9049's Avatar
sean9049
sean9049 is offline
im no expert but if it was truly just rebuilt and rebuilt correctly, then i would guess the shift solenoid they can go bad and cause these problems...some of the other guys will chime in and help way more than i can
Old 07-09-2015, 08:54 AM
Dflynn926's Avatar
Dflynn926
what light?
Old 07-09-2015, 08:56 AM
Dflynn926's Avatar
Dflynn926
I would believe it was done correctly, I have had work done by the same shop and they were really good. I do know everyone has a few bad days though.
where is the shift solenoid?
Old 07-09-2015, 09:35 AM
sean9049's Avatar
sean9049
sean9049 is offline
OD light (on the end of your gear selector)
Old 07-09-2015, 10:22 AM
fordman67's Avatar
fordman67
fordman67 is offline
Iirc reverse is solely mechanical and no electrical involved.
I believe it is broken.
Old 07-09-2015, 10:38 AM
Dflynn926's Avatar
Dflynn926
sean9049: No the OD light was not flashing, but I will look again, I may have missed it.
Fordman67: If reverse is mechanical, why did my 3 and OD stop as well? and what is broke?
Old 07-09-2015, 12:11 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,593 Likes on 1,067 Posts
There is no shift solenoid used for reverse. A failed reverse CANNOT be caused by a shift solenoid.
Originally Posted by Dflynn926
what light?
The OD OFF light on the end of the shift handle.
I believe you are correct.
Because reverse, third, and overdrive all use the direct clutch. I think the direct clutch has failed.
Old 07-09-2015, 01:04 PM
cowmilker08's Avatar
cowmilker08
cowmilker08 is offline
I hope they warrantied their work.
Old 07-09-2015, 04:51 PM
LeoJr's Avatar
LeoJr
LeoJr is offline
Would low fluid cause this problem?
Old 07-09-2015, 05:15 PM
Mark Kovalsky
Low flow where? If it were a pump issue why would the pump work in 1 and 2, but not any other gear?
Old 07-10-2015, 07:20 AM
LeoJr's Avatar
LeoJr
LeoJr is offline
I was asking the same thing Karl Childers would… The OP doesn't say that he checked the fluid level and that it was good.
Old 07-10-2015, 08:38 AM
BBslider001's Avatar
BBslider001
BBslider001 is offline
Yep, back to the shop it should and a complete teardown should ensue....then you should tell them to send that unit to John Wood or BTS and have it done right.
Old 07-15-2015, 02:17 PM
Dflynn926's Avatar
Dflynn926
Well, I am still waiting to hear back from the shop... Of course when getting it off the trailer it popped into reverse!!!
Quick Reply: e4od lost gears HELP
