DPF Question 07 6.0
on
What you might have to do if you are messing around with the emissions systems is to get a custom tuner that has tunes that disable the EGR system.
on
Although, I've never been a fan of an EGR delete and I was running modified injectors and a bigger turbo but still had a functional emissions system, but I digress on that point.
No 02 sensors. The 6.0 was the last of the diesels with minimal emissions controls.
on
If you manipulate the EGR, you SHOULD get a tuner. I would heavily suggest a tuner that allows for custom programming. Off the shelf tuners don't really do well with the 6.0.
When I used the 6.0, it was SCT and Spartan Phalanx were good choices.
on
By in mind, welding off the EGR etc, you can run the risk of leaks due the delicate nature of the welds and that can cause very poor experience as well.
DPF Question 07 6.0
No such thing as limp mode on 6.0.
You get defuel at a certain temp but that's it. I've been driving for months after my delete with nno tuner no issues. Although since the check engine light stays on I hsve to check codes more often to make sure no other code is present My main point was you can do the delete and not add a tuner until you really want too ( economic reasons) if that's his thing.
on
Having said that. Deleting the EGR is illegal, regardless if you have emissions testing in your area or not. So if economic reasons are a concern, if you get busted, there goes your savings right there and around where I am at, a few people got cited. One puffed smoke almighty bad and TN (and TX too) aren't typically gung ho about that unless you are being really obnoxious.
DPF Question 07 6.0
Correct. His being an 07 it had the strategy yhat will yhrow the low flow code. Hopefully he doesn't live where they push those things. If in a place that checks a bpd cooler would be in order or do the stealth delete by welding slugs in place but if he's thinking of straight pipe I doubt he has to worry much.
