Duraspark 2 - Wide cap vs. Narrow cap
Redroad is correct. The wider spacing on the terminals of the wide cap is to help prevent cross fire or arcing. The Duraspark systems operate at a much higher secondary voltage than the older point style systems.
For what its worth... Ford used the small caps on some of the early Duraspark systems but switched to the wide cap about 1975.
The wide cap is generally a good idea if you go with a TFI coil. With the stock '70s coil, you'll be fine with either cap style, as the voltage won't be high enough to arc across to the wrong cylinder anyhow, but as posted above, all that's needed to switch is the cap adapter, new cap, and new rotor.
on
This is all very interesting information because the Napa distributor I wanted to order today (1982 F150) was a standard size cap... which to me was a bit of a shock.
I was expecting it to be the wide cap.
The 1983 302 Cougar engine I've got sitting in my garage is a wide cap... why wouldn't a full size truck also be a wide cap?
As long as the cap & rotor match, you're basically OK.
Ford switched to the wide cap with the DSII, basically just in case the voltages got high enough to create arcing problems in the smaller cap. But as it turns out, people don't have problems running the earlier small cap with a stock DSII system - the factor of safety was just such that they were overly cautious in making that switch when they did. But, later (~86, with EFI), they switched to the "TFI" ignition system, and with the stronger coil there, the wide cap actually is necessary in practice.
My '84 Mustang had the wide cap. I used the wide cap on my build, thinking I may one day switch to the TFI coil. But I had the same coil and ICM as present on my old engine, with a small cap and never had a problem.
The distributors are actually the same. There's an adapter that installs on the regular distributor in place of the small cap to make it work with the wide cap, and the rotor for the wide cap is taller to make up for the extra height of the adapter. You can switch any time.
79F-1504x4
04-24-2010 08:49 PM
Merke
12-29-2003 12:43 PM
alpine
11-27-2002 06:33 AM
