a crab cap is flat and has the wires coming out flat and looks like a crab i have seen them on marine aplacation . i took one from a accell and it did fit but it was side ways
the spring clips on a accel are side to side on stock dist they are almost front to back and having a tunnel ram it realy interfears as i cant go to high or back or i would have run stock two piece cap i could lockout the advance and remove the pot and just turn dist out of the norm.
ps did not know the dist on a marine setup was diferent . are they like a 391?
raise your distributer and turn your cap the direction you need it and then point the roter at the post that you want to use as #1. with the #1 cylinder at top dead center on the compression stroke, of course . it should work a friend tells me that as long as the engine engine recieves spark in the right order and at the right time ,it doesnt matter which post it comes out of,good luck ,bob
Originally posted by bob arrington raise your distributer and turn your cap the direction you need it and then point the roter at the post that you want to use as #1. with the #1 cylinder at top dead center on the compression stroke, of course . it should work a friend tells me that as long as the engine engine recieves spark in the right order and at the right time ,it doesnt matter which post it comes out of,good luck ,bob
yes i can do that. and i have done so in the past .
in this setup i will have to shave off advance pot as there is the tunnel ram to deal with .
thanks Rory
