87 Bronco 2 dies when AC turned on
Working on my Bronco 2 for the 1st time today. Had some hiccups (no dip stick tube if anyone has a spare to sell). But I noticed when I first started it the day I got it it immediately died. Will run after hitting the gas a few times. I was originally thinking fuel pump. But when I tried the A/C today the truck immediately died. heater does not work. I knew this truck would be a project so I'm not to stressed. Any ideas on the dying with AC on issue?
88 & newer b-2s and Rangers have a check engine light to let the driver know there is a trouble code stored in the ECM/computer. The codes can be very helpful for finding a problem.
Whenever I have a problem with my 87 Ranger I do 3 quick and simple tests:
1 Check for trouble codes
2. Screw on a fuel pressure gauge and check the fuel pressure
3. Test with a vacuum gauge.
If none of these tests are helpful for figuring out the problem, the truck goes to Castners auto repair in Yorba Linda, Ca.
Forgot to mention that I scanned thru the 99 trouble codes in my Actron code scanner book and unless I missed it there are no trouble codes for a bad IAC. I guess the ECM/computer doesn't monitor the IAC to see if it has a problem.
Sometimes cleaning the IAC will fix idle problems, sometimes it needs replaced.
But b4 I replaced anything I would do the 3 tests I mentioned.
Southfork894x4
06-22-2012 09:45 AM
dep295
08-06-2008 06:11 PM
billyb
09-09-2000 11:41 PM
