1948 F1 Dash
Old 07-10-2015, 02:35 AM
White Lion's Avatar
White Lion
White Lion is offline
Originally Posted by ALBUQ F-1
I believe I see a "C" on the head casting number, which would indicate Canadian production. Canada produced many of the export trucks.
Thanks for the info and I always suspected that this truck may have originally been produced in Canada. I will get under the hood in a moment and take a shot of the casing number.
Old 07-10-2015, 06:48 AM
White Lion's Avatar
White Lion
LH side
RH side
Close up of the stamped castings LH and RH with the USA underneath
Old 07-10-2015, 08:45 AM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is offline
Ross, Thanks for the reply. That doesn't sound like a good setup using the crimped nut for a ground cable. That would make for a very long cable. What then would be the purpose of the crimped nut above it, just above the bead?
Old 07-10-2015, 12:34 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Mark, there are TWO braided cables. They were essentially using the firewall as a conductor to use two shorter cables. Not a good idea IMO.
Here's some pics where you can kind of see it. In the one pic, you can see the cable from battery to the firewall behind it. In the other you can see part of the cable from behind the air cleaner to the intake manifold (or BH, not sure). You can barely see the second cable just on the left of the carb.
Edit -- I just realized the nut in question is clearly visible in the pics and unused! So the mystery continues... Must be for Big Truck accessories.
Old 07-12-2015, 01:22 PM
petemcl's Avatar
petemcl
petemcl is online now
Still Learnin'
That is a very nice looking truck DW. Thanks for sharing the pictures. I agree with Bob that the hole in the dash that you asked about should be for the wiper switch. When you get up under the dash you may find out why. If it was converted from vacuum to electric the new switch may not have fit.
I can't really tell from the picture but it looks like your truck has no cowl vent. If not while you are under there you might look up to see if it has a patch panel of was built that way. Sheet metal is often locally sourced and since South Africa has been a major steel producer that would make sense.
As for the weld nuts on the cowl I have the upper one too (the second hole has no weld nut). It has been a while since I took that apart but I think that it had a radio support on it.
I also found these videos on line that might interest you of the Port Elizabeth plant in the 40s.
1940s video Ford's Port Elizabeth assembly plant
52burjes
07-17-2019 11:40 AM
Pokee
03-02-2019 08:30 AM
acl9865
05-08-2017 09:23 AM
gdub
10-13-2014 04:56 PM
mette
04-30-2008 07:56 AM
Quick Reply: 1948 F1 Dash
