Name this pulley!!
Old 07-03-2015, 04:21 PM
mudrat025's Avatar
mudrat025
mudrat025 is offline
Name this pulley!!
Hello I was wondering if the middle pulley under the as pump was just a idle pulley.thanks
Old 07-03-2015, 04:24 PM
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
That is your vaccum pump.
Old 07-03-2015, 04:49 PM
mudrat025's Avatar
mudrat025
Thank you!
Which one is the tensioner??
Old 07-03-2015, 04:52 PM
stainlessstroker95
The top one
Old 07-03-2015, 04:53 PM
mudrat025's Avatar
mudrat025
But do I listen at 15mm bolt or torx???sorry but I am at a campground and running low on time
Old 07-03-2015, 04:54 PM
mudrat025's Avatar
mudrat025
**loosen. Damn autocorrect
Old 07-03-2015, 05:06 PM
madpogue's Avatar
madpogue
madpogue is offline
Are you removing the belt, or the tensioner?
The 15mm bolt holds the pulley onto the tensioner. You also use it to wind up the tensioner spring in order to relieve tension on the belt to remove it. When you do this, you're not turning the bolt, you're simply using it as a "grip" point to put a wrench on it to gain leverage on the tensioner arm. When you get the wrench on, push it counter-clockwise to wind up the tensioner spring. Then slip the belt out from the under the smooth idler (top center of the engine, between the A/C and alternator pulleys). Then you can let go of the tensioner and remove the belt the rest of the way. To re-install the belt, thread it on to all the pulleys, but run it straight across from tha alt to the A/C (above the smooth idler. Then wind up the tensioner spring (again, push counter-clockwise on the breaker bar), and while you're holding it wound up, slip the belt under the center smooth idler. Let go of the tensioner, and it will tension the belt. Check for alignment on all pulleys.
If you're removing the tensioner itself, first remove the belt as described above. THEN you loosen and remove the torx bolt at the pivot point of the tensioner (it's NOT reverse threaded), and the tensioner comes out of the bracket.
Old 07-03-2015, 05:21 PM
mudrat025's Avatar
mudrat025
Thank you!
1974 f100
13
05-23-2017 08:52 AM
jbehuniak
05-03-2016 08:01 AM
gfburke
WTB - Parts & other
06-10-2015 05:30 PM
Cody_1948
15
03-21-2014 07:38 PM
cbfomoco
11-22-2005 02:28 PM
Quick Reply: Name this pulley!!
