i would like some advice/opinions on a 300 swap into a 50' IHC. please
hi, I have a 1950 international L110 that's very tired. it does run and drive, but the 3 speed "screams" at me when I let off the gas. I've been contemplating my alternatives. I'm not "rich" by any sense of the word, but would like a daily driver out of this. Ill be renting some shop space starting in august, so I'm deciding my route. the truck will need to tow our #3500lb vintage travel trailer. it would be costly to rebuild the current engine. it's a 220. I did pickup a 4 speed (t98) from a 55 IHC, but its still a 3spd with granny. I have already got a ford 8.8 out of a explorer for it. I like the big 6 as I don't have to redo my steering, it looks similar and will have more "**** in it's britches".
I have been doing some reading and it appears I can turn a 240 into a 300 with a crank, rods and pistons. is there a kit somewhere? (I may have located a 240 and 4spd reasonably priced)
I want to lower the truck, give it that "hot rod" look and run twin pipes.
I don't want an automatic.
what (years) engine/trans would YOU look for? how would YOU modify it?
thanks for your input
on
Whatever you decide, take pictures and post here!
I would EFI it and use a newer 87 to 96 block, but those long intake runners turn some people off. If you use a custom EFI computer, you may wish to look into turbo for a neato hotrod, but forged pistons are a problem sourcing...
edit: I'm kinda weird because I wanna EFI everything ;D
With that ford 8.8 and the 300 it might just be ok with the 3 spd tranny.
But I think it will still scream at highway speeds and you will want to find something with an OD.
EFI would be nice but a kit is going to set you back over 1500 maybe more. Haven't looked at prices (in a minute) I just know it's a bit of sticker shock. I'd spend it on a tremac tko tranny that has OD before I spent it on EFI honestly.
Or find a zf5 attached to a 300 and get er done.
(this would probably be the cheapest route)
I have a friend with the very same truck (split-window) contemplating the very same swap.
Personally for towing I would go with an automatic but if you want a stick get a mid-80s Ford cast iron 3+1 four speed toploader with overdrive and an available factory floor shifter.
It is a lot of work to convert a 240 into a 300. I would just find a carbed 300 to put in.
wow! thanks for the responses! internet is spotty as i'm traveling this weekend.
i know EFI is more effiecent, just doesn't look old school enough
i will have to look into the TKO, ZF5, and toploader. not sure, but would assume i'm looking for one in a truck?
Frenchtown Flyer, i will take your advice on the 240/300 change. I've read a lot of your posts here and elsewhere, so i know you know your stuff.
Mtphammer, what trans did you use? do you tow, or just cruise?
thanks again everybody!
Michael Sloan
01-13-2018 10:47 PM
tim1970f100
08-31-2008 12:10 PM
