Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Parts source for a 1965 C600?
Old 06-30-2015, 02:25 PM
iPlowNH's Avatar
iPlowNH
iPlowNH is offline
I ordered the CD for the Ford truck Part numbers. I need odds and ends of stuff like weatherstripping and other odds and ends of stuff. I called local Ford dealer and got the chuckle from the parts guy when I sad 1965 C600. Is there any only sources? Or used truck graveyards? I am in New Hampshire.
Here's what the Vin Plate revealed: (thanks Bill!)
C61 = C600 (gas).
M = 330 2V H/D FT Engine.
U = Louisville KY Assembly Plant.
732162 = 1966.. assembled August 1965.
153" Wheelbase.
9 = Not listed for 1965; 1966 or 1967, could have been a mistake, as *J* = Rangoon Red.
C612 = C600 (gas) .. 22,000 lbs. GVWR
A91: A = Light Gray Crush Vinyl & Gray Twill Stripe Woven Plastic / 91 = 91B Custom Cab.
L = Clark model 2651-V1 or 2653-V1 5 Speed Direct.
*-*(blank)D: Blank = Rear Axle was a Domestic Special Order / D = Ford Rockwell-Timken 7,000 lbs. Capacity Front Axle (Special Order, but not a DSO).
22,000 Lbs. Gross Vehicle Weight Rating.
160 net HP @ 3,800 RPM
131368:
13 = NYC NY Ford District Sales Office, where the original selling dealer ordered the truck from.
1368 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
The rear axle is a Domestic Special Order, but there's no way to discover what it is, or what else might be a DSO, as FoMoCo THREW AWAY all the records decades ago.
Old 06-30-2015, 09:56 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
You have two choices:
1) List all the parts you need here in this forum, or...
2) email me: sylhall@aol.com and we'll discuss all the parts you need.
I'm in CA
Old 07-01-2015, 10:20 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
For the benefit of the forum, it would be better to do it here than private email...
Old 07-01-2015, 10:32 AM
NumberDummy
I disagree, simply because there would be a tremendous amount of typing I'd have to do.
OP wants weather strips, there are 2 for the windshield, 1 for the back glass, 2 for the quarter windows, each door has 6 w/strips.
All are obsolete. I'd have to post all the part numbers, then search and type the sources/phone numbers for any I found NOS
Plus the OP wants other 'odds and ends.'
Old 07-01-2015, 12:06 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
You don't type email?
Old 07-01-2015, 12:11 PM
NumberDummy
I get the OP's number, pass out the part numbers/sources using the "Ameche." Much easier doing it this way than typing 100's of words with arthritic mitts.
stully
09-20-2018 09:48 PM
watongaokie
Large Truck
04-30-2017 11:08 AM
iPlowNH
Large Truck
06-24-2015 06:23 AM
Jdhacker
06-02-2013 06:18 AM
Kriesel
05-29-2012 04:19 PM
Quick Reply: Parts source for a 1965 C600?
