460 Smogger Street Cam
I have a 1973 F-100 with an early 70's low compression Lincoln motor in it. I want to change the timing gear set so it isn't so badly retarded and get it up to pre 70's spec. I also have some C8VE-E heads off of a 429 CobraJet that I want to install to get the compression up.
So as long as I am doing all this work it seems to make sense to swap the cam out as well. What is a good streetable cam to throw in there? This is not meant to be a race car, just a fast ride to the home improvement store and used lightly. I will be using a stock C-6 trans. Thanks!
on
rudifisk
06-28-2015 01:21 AM
1972 Ford Thunderbird 429 V8
03-26-2003 07:55 PM
nothingbutford
05-22-2002 11:15 AM
tatonka
08-23-2001 02:11 PM
