2006 Ford F-150 - Drivers Power Window - Wont roll up
Rolled it down yesterday. Wont roll back up. Without hitting any buttons, I hear a click in the door every 15 seconds or so. During these 15-20 seconds, when I hit the power window button, the door makes a clicking noise like it is trying to activate the motor, but nothing happens. Then it clicks, and for the next 15-20 seconds, no click, no noise, no matter how many times I hit the window switch. Then after the next click, i will hear a click again whenever i hit the button, and so on and so on, on and off every 15 seconds. I tried taking apart the switch box and checking the contacts. they were fine. that is as far as ive gotten.
Most likely the "regulator".
I've temporarily placed the Window section from my 2005 Factory Service Manual in a public directory for you to download. You should be able to print it or save a copy to your computer.
www.devoll.com/Public/F150-windows.pdf
Hope this helps.
Hope this helps.
@FlyingAl
Guess the decibel level of the clicking and noises @SoundPreservation mentioned caused feedback in my hearing aid. You have a completely valid point. Thanks for filling in the missing parts of my response. I am adding the window wiring diagram from my Factory Service Manual for SoundPreservation at the public link:
www.devoll.com/Public/F150-window-wiring.pdf
It should print out directly or can be saved to your computer. Hope this helps
Best of luck.
Best of luck.
78_79ford
11-16-2014 12:13 PM
manderson99
Electrical Systems/Wiring
10-17-2013 06:22 PM
