RIP 272
Old 06-25-2015, 01:25 PM
Textile302's Avatar
Textile302
Textile302 is offline
RIP 272
272 in my 1960 F100 decided to blow both head gaskets. Was going to do a rebuild and discovered some jackass PO had filled the block and head full of Bar's. Block and heads are so clogged they are pretty much done. Also found some bits in the oil pan from a previous iteration that grenaded. Explains why my radiator was so full of junk.
Gonna start over with a 55 292. This is by no means a big $$ build but I don't mind doing things right so I can bolt on some power later. Any suggestions on what I should use?
Some pics of the 272
ARP Bolts? Nope... More like AARP Bolts
So clean you could eat off it...
Nope, Engine NEVER Overheated
One of these is not like the other..... Its glazed<br/>Glazed!
Old 06-25-2015, 07:02 PM
spurredon's Avatar
spurredon
spurredon is offline
Well, at least you have some decent valve covers! LOL
Old 07-01-2015, 03:18 PM
Col Flashman's Avatar
Col Flashman
Col Flashman is offline
Are you sure it is a 272ci, because the Last of the 272s were installed in '57.
Production run was '54-'57 here in the U.S. in Trucks.
Old 07-01-2015, 03:34 PM
Textile302's Avatar
Textile302
God only know's what happened to the original 292 block. Block we pulled out was an ECG block which was housing a set of 292 pistons bored 40 over. ECG is a 272 casting so pretty sure there wasn't much meat left on that block. Water passages were so clogged up with bars and rust, we just opted to find a new block. Currently working on a 1955 292 and taking the best parts of each to build a new motor.
We found bits of a previous build in the oil pan, and since the crank we pulled out is cast, my best guess is they got the 272 from a car, and used what was left of the original 292 to make it work in the truck.
Old 07-01-2015, 04:25 PM
hiball3985's Avatar
hiball3985
hiball3985 is offline
Steel cranks were only in 1961 and later medium and heavy duty trucks.. All light duty trucks and passenger car 272/292 had cast cranks
Old 07-02-2015, 09:13 AM
Textile302's Avatar
Textile302
Interesting, I was under the idea that all truck motors got the steel cranks. Learn something new. Thanks!
1browski
06-30-2019 03:12 PM
JimScott
16
09-28-2018 06:08 AM
IDIoit
25
11-24-2016 07:06 PM
TMI
02-19-2016 06:32 PM
Quick Reply: RIP 272
