1983 F-800 Towing Capacity/Power
I Searched High & Low PLEASE POINT IN RIGHT DIRECTION!
I have a 1983 Ford F-800 Dump
33,000 Original Miles
Ford 8.2L 501cid V8 Diesel Turbocharged Motor
5-Speed with Split Shifter
GVWR 30,200
GAWR Front 9,000
GAWR Rear 21,000
Truck Weight Empty 14,000
Will it have the Power & Safety to Tow
Excavator Volvo 140CL on a 20 Ton Split Tilt Trailer
Center Loaded over axels 45,000 lbs Total with tongue weight of 6750lbs
GVWR 30,200
GAWR Front 9,000
GAWR Rear 21,000
Welcome to FTE.
OK, you already own this truck?
What is the HP rating of that engine? From what I can find, there are several versions.
You have a CDL, correct? I don't know much, but I would expect a CDL holder to be able to figure out some of this, especially if you own and have driven the truck.
I would guess you will be marginally to inadequately powered with 45000 lbs. behind you.
Got all the plumbing for your air brake connections? What else does the trailer have in the brake department?
Pintle rating? Frame and crossmember set up?
What to Know Before You Tow: Dump Truck Towing Tips
That article says 42000 behind a 3 axle dump, so with what little I know and based on my limited research, I would say you can't pull 45000 lbs with a single axle dump.
More discussion, some with loads approaching what you propose.
Single axle tow capacities
I've tried to find something about this on the MA dot site, but no luck. I would call them direct.
jerryparks
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
07-03-2019 11:15 PM
Ibby
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
05-03-2006 09:41 PM
ibf250
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
36
12-08-2004 08:19 AM
