2015 F350...How do you open the center console lid?
I had the same problem. Took it back to the dealer, there was a small piece of rubber under the latch they forgot to remove. It is there to prevent opening during transport. If I remember right pull back on the latch and look down at the front of the latch towards the cupholders. It should be in there. Just remove that piece of rubber and you should be in business.
Agreed. I had the same piece of rubber stuck inside. I saw it with flashlight. I thought it was a pencil eraser. Can't remember how I fished it out of there.
Best luck to you
-DT
I just experienced this and you guys helped me figure it out. Thank you! But, I wanted to point out that the piece of rubber has nothing to do with transport and needs to remain there. It is a little ball that rolls into place when you put the seat up to make sure the lid stays closed and your stuff doesn't fall all over the place. Mine got stuck because my 5-year old tried to open the lid while I had the seat up & it wedged the ball in there. Once I put the seat back down and poked the ball back down, voila!
stngh8r
06-24-2009 01:09 AM
