I have a 2001 ford escape v6 the engine light is on and when advancs pulled a code it came back egr valve is sticking and #2 is not fireing.. I have a 2002 v6 parts car that I ran hot I took both parts off and put on my 01 buts its still running the same.. anybody knows anything on this.
Go back to the parts place and have your codes re-read; write down the codes and then Google them unless you have access to AllData or the factory service manuals which give you step-by-step procedures to further diagnose the issues.
Diagnosing the EGR will take a little time. You will have to see if you are getting signal to the solenoid.
Cylinder 2 misfire could still be a bad coil. Swap it with a known good one that is already on your vehicle and see if the code follows the coil.
