1997 F-250 7.3L Help!!!
1997 F-250 7.3L 280000mi .... truck will run good then shut off when going down the road will not start backup again the wait to start light will not come on truck will turn over just fine..... after about 15 to 20 min the wait to start light will come on and truck will run good.... checked #22 fuse and checked the back of fuse box for bad connection... when cranking you can see rmps. I have let the truck sit and idle for almost 2 hrs with no problems any suggestions??
I changed it this morning and drove it around most the day with no problem then I died again... I noticed when trying to crank it you can see the rmps on the dash but the wait to start light never comes on... about 20min went by the I tried it again the wait to start light came on then it fired right up.
Dave Garrison
16
01-07-2019 07:38 AM
shark1979
06-01-2012 06:37 PM
