is my lift the problem??
I am taking my truck to the dealer tomorrow to have the rear end worked on. I believe the whole rear end is dead. It started making a grinding noise after i had the dealer replace a front pinion seal that was leaking. Does my 6" susp lift void my warranty. My service guy said it truly does void it but he was not saying anything about it and was still going to service it under warranty. But my concern is WHAT IF THEY CANNOT FIX ALL THE PROBLEMS and i try to turn it in as a lemon will they blame all the problems on my lift?
Originally posted by bryan78f1504x4351mc6A
hm, grinding from the rear or front after they replaced the front pinion seal? if from the front, its very easy to screw the nut on to tight, after replacing seal, placing to much load on your bearings, and nuking your front end.
Seeing that your rig is a 2003, just by changing the stock suspension, you may have voided your warranty. Depending on:
The shop that installed your lift, are they certified through FORD or sponsored by a Ford Dealership?
Why isn't the shop that installed the lift doing the repairs? Did you sign some type of waiver to accept responsibility for the lift and the problems you may encounter?
One last item. Since you've POSTED the pictures of your rig, there's no way you can turn the truck in as a lemon. Sorry...
I wish I could take everything back that didn't work out in my favor.... Talk to you guys later....
06greenstroker
6.7L Power Stroke Diesel
11-25-2016 12:26 PM
Jaytrain01
01-28-2002 05:03 PM
