Bought truck with only one key
You have it right Dannyboy950......I was lead to believe there was a chip in the key and that was where all the expense was involved, I guess it was just too much temptation for the dealership to just tell me it would be a few bucks at my local hardware store for a second key. things like this is why I rather have a sister in a **** house than a brother working in an auto dealership
Maybe I'm being to forgiven in this instance but really what's his gain?
The real test is hand him the key and get an actual cost.
Also to identify, the PATS keys have an offset hole.
Since your truck is only a year off before they did use the chipped keys in trucks and now a days practically all the Fords have them I think your being a little harsh. If he had it in hand he might of caught his mistake but you just got a quote. You were given a verbal quote for the cost at most. It's not like you were charged.
Mark could a older truck be converted to PATS? I know that was not your
thing but thought you might have an idea.
Was that the tech or the moron that worked as a service advisor?
I have found a few that make a box of rocks look like they have a PhD.
I know not saying much there
Sean
I'm not looking for a pissin contest here but if the Ford service technician wasn't sure of what my 07 needed for a key and how much I could expect to pay for it he shouldn't have quoted me a price so fast, a couple pf questions could have clarified that for him and just maybe I might be as forgiving toward him as you appear to be...He didn't and I'm not. This same dealership sold me the 07 F350 with a new Fisher extremeV plow and two weeks after I started plowing with it the lift cylinder started puking fluid out of it and onto my grill,hood and windshield....their answer for that was " all plow cylinders leak after a while" all this after they made me drive the truck forty miles to them with the plow attached. I weren't happy with that answer and I'm not happy about the key incident.
Sean
When it comes to the options are the Harley's counted as a F-series or an Excursion?
I am finding that the VSM for the F-series does not have a pin for the PATS input
from the antenna. Also I would guess that the cluster has to have the light and
there has to be a signal to tell the PCM to not allow a start.
Sean
Sean
I actually am absolutely certain the excursion is the only 6.0 equipped vehicle that can have pats. The Harley trucks do not have chips. As funny as it sounds,, they only have the bigger key so the Harley emblem can be on it. The ring on the ignition and the little computer box is hard to miss on a pats equipped column.
Sean
Sean
I'm not saying all dealerships are like this....just all the ones I've had the opportunity to visit.
If you've ever had to unlock a vehicle multiple times for the same person because they've locked their keys in the car you'd understand
