Ford Racing oil filter adapter
One of the benefits, not the key benefit of the Ford Racing filter adapter I was expecting was "cleaner" oil filter changes. Wrong. At least for me. The other benefit that I am sure it accomplishes is not letting the oil backflow out of the filter. I was seeking that to see if that would help quieten down my engine on initial starts after over night or long delays between running. Did not help in my situation on my 69 f100.
But I do like the look and the methodology behind the adapter and bought one for the 240 I am having rebuilt for my 71 f100.
As to why it doesn't make for a "cleaner" oil change. The quantity of oil stored in the housing of the adapter is pretty substantial, so once you start to loosen the oil filter, it flows out as the filter is already full. Second negative - oil filters are not as easy to remove and install.
Just my two cents.
Just my two cents.
I think if I was going to go through the trouble of running an adapter. I'd just go a step farther and go with a remote mount filter/s. That way you can mount it where ever it would be the easiest to deal with. And then you aren't dumping oil down the side of the engine or all over the crossmember when you change your oil.
One of my Dad's RX-7s (maybe both) had a remote oil filter. It also had little cooling fins on that remote filter block AND a remove oil cooler on the 13B rotary. Those little buggers really needed a lot of oil cooling.
The best part of the remote mount though was that it was mounted "upsidedown" so you spun off the filter and lifted it right out. No mess.
the downside was having to have a good anti drainback valve and no easy way to prefill a new filter.
Just my two cents.
Just my two cents.
Of course if you want to change it hot it's a little trickyier.
One thing about the filter. I was disappointed in the fact that the big "bolt" attaching it to the engine rusted over.
Hey what kind of oil filter are you using? Hopefully not a Fram their junk that's probably the reason for the noise on start up get a Motorcraft or Purolator oil filter!
Just my two cents.
Just my two cents.
