Has anyone ever but an 02 turbo on an e99, My turbo went out today and I have a spare from my 02 that went t4 in the garage and was wondering if my e99 ebpv delete pedestal will work and can I just bolt the turbo on or do I have to change the pedestal as well or what other problems might I encounter ??? Thanks
You'll need to change pedestal, up pipes, manifold and plenums. OR you can swap the compressor housing and backing plate to the turbo with the good center housing. You may also be able to rebuild the bad turbocharger. A rebuild kit is under $100.
the OR sounds like a better option, i actually have a 98 van turbo, i think i'll use that center housing, time to call Bob for some new o-rings, thanks Pikachu
I have a early 99 turbo sitting in my garage if your interested. I swapped to a late turbo myself. There is quite a few parts that need to be swapped out like mentioned above.
Thanks FF1406, i wish i had seen this earlier, just ordered the van outlet and new orings and a clay's wheel if it doesn't work out i'll hit you up and the offer is much appreciated.
