Looking into getting a truck from this era.
I'll throw out there that the 351W is a great engine, but fitment can be problematic. Depending on motor mounts, transmission choice, etc. I've worked on Fords all my life. I swapped a 351 Cleveland and C4 into a 79 F100 with zero issues. Putting the 351W and C6 in my '72 F100 has been a challenge. Even with the correct 302 motor mount stands, I had to redrill the frame and crossmember and move them forward for the drivers side head to clear the firewall. I cut out the floor hump and got a bolt on cover to clear the C6. Headers are still a challenge I haven't solved yet. Just some thoughts.
Try to find the most rust free truck you can find. That's the biggest challenge.
I did the same thing with the 351W in my 68. I got some engine perches from a 302 truck and mounted them in the same position but my head was barely hitting the fire wall so I moved the perches ahead 1" and it fit fine. Minor adjustment so I wouldn't say 351W fitment was a problem though. I used a C4 so I had no problem with a low hump and I used the original trans crossmember just drilled new holes in the frame.. I've just used the stock exhaust manifolds, no headers.
I probably won't start looking hard till next summer though.
I think I'm going to ultimately regret it if I don't do a cv swap. Which will push the timeline out farther and may make me rethink my engine options. mod swap/coyote swap wouldn't be out of the question.
Oldcrowbarber
11-23-2018 01:12 PM
csm
02-18-2013 04:19 PM
dqnguyen56
03-15-2012 10:54 PM
luckykillebrew
11-13-2001 05:58 AM
