2001 Excursion - Mystery Front End Clunk Getting Worse
I had similar problems on my 2000 excursion.
Clunk was sway bar bushings, I couldn't readily find the sway bushings, so I bought and replaced the entire assembly. Still get an occasional clunk, but nothing like before.
Grinding - my grinding was the inner needle bearing in the hub that support the front axle shaft, right front like yours. Of course ford does not sell those separately, they will just sell you the entire hub assembly $350 - $400. I measure the needle bearings and started calling around. Found replacements for about $10.00 local. That was two years ago, all has been well since.
Well, I found the grinding noise. I finally got a chance to take it apart tonight. My guess is I've got a stuck caliper as well. Can you get caliper rebuild kits for these, or should I just get a new caliper? Luckily, it's on the rear, so not a huge deal. I guess the guy that inspected it last month didn't really look too close.
