1988 Ford F150 rear window
Old 05-28-2015, 07:56 PM
rugermack's Avatar
rugermack
rugermack is offline
Is the cab around the rear window different if you had factory rear window(slider vs. single pane window) ?
LMC gives 2 different seals,
49-9286 without groove for trim (A)
49-9279 for truck with original rear sliding window. (C)
My truck had a slider but not sure if it was original slider.
Not sure which seal I need, are they different ?
Old 05-29-2015, 04:30 PM
wag53's Avatar
wag53
wag53 is offline
The factory slider is thicker than the flat glass. If it is a factory slider the seal area will be approx. 5/8 " thick. That is the 9279 seal, flat glass and most aftermkt sliders use the other seal. Rear glass is the same from about 1980 to 1997 for sure, maybe more.
Old 05-29-2015, 04:56 PM
rugermack's Avatar
rugermack
Thanks, I bought the 49-9286, I'm glad I ended up with the right one.
Millam
08-18-2018 05:32 PM
abyars111
16
07-21-2015 06:55 PM
OFLM
04-17-2015 07:08 AM
FordFanboy
09-11-2014 09:21 PM
MGT351
04-05-2004 05:54 AM
Quick Reply: 1988 Ford F150 rear window
