F600 fire truck UK
F600 fire truck UK
Hi
Introducing my new toy.
Plan is, to keep it looking like a fire truck from the outside, but fit it out like a dayvan / weekend camper inside.
Still not sure what to do with the fire pump.
First job is getting the wrap off it, fortunately I got it when I did, as the wrap was well on its way to destroying the truck. It was trapping moiture around the edges and under any voids on the more curved areas, causing rust. So far only one small area that requires a patch, not bad for a 49 year old.
currently lots of peeling, sanding and painting going on.
more updates to follow, as I do them.
I'll go a bit of a different direction if I may. Regarding your truck's wheels. They are, here in the U.S. anyway, a pariah. They have two part outer rims known as the Firestone RH-5° design. Finding service for them is impossible in some areas of this country, and difficult in most others. Do you have knowledge about them, and whether they can be serviced in the UK? Replacement tubeless 22.5" wheels can be found here having your 6 lug x 8.75" pattern. Stu
Thanks Stu
I have been reading up on these trucks before and since purchase, and as you say the wheels are a concern.
Tyres are also not easy to find, so I am looking in to changing to 22.5 wheels and tyres, I will probably go to super singles on the rear ( just for the hot rod look). It will require adapter plates but I can get them made at work, as we don't have a plentiful supply of U.S. trucks in breakers yards over here.
cheers
cheers
Cheers mate...
Welcome to the forum
Nice looking truck
Learn how to use the search button here ..it will be your friend
I posted where you can get new 22.5 rims in a post on here... you will find it.. they actually come over from Europe so with some investigation I just bet you can get them cheaply on the other side of the water.
As to your pump... it sounds like you are going to refurbish it not as a fire engine.. so actually you will be deconstructing it and then re-purposing it as a camper.. which would be an awesome use for it
Taking the pump out ( I couldnt tell if it was driven from a pto or driveshaft) will be a lot of work but worth it.. you will be shedding hundreds of pounds of iron.. all those valves and lines add up quickly.. some good sheet metal work and you will never know they were there
Parts are going to be an issue for you but there are a number of trucks of your vintage here in California
You can check craigslist sacramento where I have seen several for sale.. for a long time.. and he might part them for you
Good luck on your project!
Nice looking truck
Quick update-
Picked up some super singles today, will be getting adapters made up soon.
Vinyl is coming off slowly, tried heating etc etc but scraping is proving the most effective.
Bought some coach paints, filler primer and gloss, from Craftmaster paints, very pleased with the results so far, and Abranet sanding discs are so so much better than conventional discs.
Notmeofficer- A lot of the pump is made of bronze, and the valves are all bronze also, I'm tempted to clean and polish it, and yes it is driven from a PTO likewise the hydraulic pump for the winch.
While I intend to fit it out a'la dayvan with a 50's diner style, I want to keep all the external fittings to maintain the fire truck look, all that chromed brass is too good to get rid of.
My plans are still developing as I strip the vinyl.
cheers
cheers
Awesome progress..its really cleaning up
Could you tell us more about your super single swap... they appear to be adapters that bolt on the six lug rockwells...
Were they custom made or is there a source for them over there?
cheers!!!
Thanks, progress was going well until the windscreen incident.
The super single conversion is down to the adapter plates, just a flat 1/2" plate with appropriate holes, I picked up some wheels and tyres on e**y for a good price and had the adapters made to suit.
The wheels have a fairly standard 335mm pcd. I will also be changing the front wheels, but have yet to decide on wheel/tyre size.
Struggling to decide on the colour of the bumper/front grill at the moment, current choice is red bumper and silver grill, but I may go for a silver bumper and grill......
Then again a black bumper might look O.K hmmmmm
JAFFAR3869
56
02-25-2012 03:35 PM
