Dummy alarm lights on my f250 help
Hey I just purchased some led dummy lights off eBay , it has a positive and a negative . I was wondering is there a wire that either grounds or turns hot when I turn ignition off for the led to start blinking ? Here's the item I purchased Check out this item I found on eBay: http://pages.ebay.com/link/?nav=item.view&id=141451225044&alt=web
I don't know of any power source that is switched hot with the key off.
What you will probibly have to do is install a normally closed SPDT (single pole double throw)relay that activates with a key on power source. When you remove the power the relay closes completing the circut and the light starts flashing.
Using the diagram above...
Replace the line with a switch to a line that receives key on power.
Using a SPDT relay the relay will close when you remove power ( shut off the truck) completing the circut and illuminating the LED.
When you switch the truck to run, or start it the relay will open removing power ( or ground depending on how you want to look at it) from the relay and the LED will shut off.
I found something on YouTube ok find a constant power supply in the fuse box I used the horn fuse then I put the ground tapped into the auxiliary empty fuse and it worked ! Lol when I turn ignition on light stops blinking when I turn ignition off it starts blinking didn't need to buy now relay or switches .
idbl_fanatic
1997-2006 Expedition & Navigator
12-22-2006 07:08 AM
