column & shift linkage
I'm having an intermittent problem with my automatic column shifter. It will sometimes fall from "D" to a point in-between "D" & "2". This is on my 1970 F250 so it rides rough and seems to be jarring it occasionally out of "D". I'll notice it sometimes when the truck starts off from a dead stop in 2nd. I thought I was having other problems until I realized what was going on. Is there something in column or trans itself that would allow this? I"ve checked trans. vacuum modulator & kick down rod. They are getting good vacuum or or properly adjusted.
You should have to pull the shift lever towards you to go from "D" to "2". Just like pulling it out of "P". The transmission control selector position insert is what makes you pull the lever towards you. Over time and use this insert gets worn. So I am assuming yours is. Usually allowing a shift lever to come out of park more often than D to 2. 1969 from serial number D96,001 to 1971 is part number C9TZ7A216B. Discontinued. None on my 3 locators.
Hey Bill. Can you please post picture Illustration section 35, page 8 please.
That's what I was afraid you'd say.
I have to pull it towards me to come out of Park and reverse but it moves freely between D 2 & 1.
I had it all apart a few years back to replace the shift collar. I saw some rubbing but wasn't sure how much was bad. I have a positive lock when it's in "P". I've been afraid of that dropping out of park thing. I just didn't remember if the D 2 & 1 section had positive stops on them. Thanks for the part number I'll do some searching. If you find a dealer with one I'd appreciate the tip.
The transmission control selector position insert (7A216) is what makes you pull the lever towards you. Over time and use this insert gets worn. So I am assuming yours is.
1969 from serial number D96,001 to 1971 is part number C9TZ7A216B .. Discontinued. None on my 3 locators.
Right lower: Look at the bottom of the column for the 7302 selector lever. Pic shows a bushing and insulator in it, but that's only for 1964/68.
1969/91's have a nylon bushing that snaps into the lever, when it cracks apart, will affect the shift lever position.
E0SZ-7341-B (replaced C7SZ-7341-D - C8OZ-7341-A - C9TZ-7341-A - D5TZ-7341-A, B, C) .. A/T Nylon Selector Lever Bushing / Available from Ford.
1969/91 F100/350 - Myriad 1960's/80's Passenger Cars.
Zoom
<table class="table table-striped table-boxed"><tbody><tr class="odd"><th>Make</th><th>Model</th><th>Body Style</th><th>Notes</th><th>Year</th></tr><tr><td>Ford</td><td>Bronco</td><td>U-Series</td><td>- </td><td>1974-77 </td></tr><tr class="odd"><td>Ford</td><td>Truck</td><td>F-Series</td><td>- </td><td>1965-72 </td></tr></tbody></table>
<!-- applications-wrap -->
<!-- tab-applications --> Review Summary
- No Reviews
- Overall Rating: None
- Be the first to review this product
<!-- tab-content --> <!-- col1 -->
<form name="ShoppingCartAdd" class="form-horizontal buynow" id="ShoppingCartAdd" method="POST"><input name="formName" type="hidden" value="ShoppingCartAddAJAX"> Our Low Price:$11.95
<!-- price-wrap --> Trans Gear Shift Socket Indicator
1965 - 77
D3TZ-7A110-A
No Reviews
<!-- <input type="hidden" name="formName" value="dmiformShoppingCartAdd" /> --> <input name="productNumber" type="hidden" value="D3TZ-7A110-A"> <input name="parentProductNumber" type="hidden" value="D3TZ-7A110-A"> <label class="control-label control-label">Status</label>In Stock
Sign In to Add to Wish List <button class="btn btn-primary" id="cartbutton" type="submit">Add to Cart</button>
<label class="control-label control-label" for="qty">Quantity</label><input name="dmilist_Qty_100000050649" class="input-mini" id="qty" type="text" value="1">
</form><!-- buy now --> <style type="text/css"> .imgBox:hover { -moz-box-shadow: 0 0 10px #ccc; -webkit-box-shadow: 0 0 10px #ccc; box-shadow: 0 0 10px #ccc; } </style>
<!-- badges --> More
1965/77 F100/350 & 1973/77 Bronco & Econoline:
D3TZ-7A110-A pointer also furnished with D5TZ-7228-A shift collar kit (available from Ford): Replaced C5TZ-7228-A; C9TZ-7228-A & D3TZ-7228-A shift collars.
1965/68 & 1969/72 collars came with the pointer made as part of it.
D5TZ-7228-A (D3TZ-7228-A) shift collar comes with a slot in it, for the plastic pointer to slip into.
No, I'm sorry, I got my termonology mixed up.
I meant I'm going to keep a look out for the selector position insert you mentioned earlier. The next trip I take to the junkyard I'll disassemble a few columns and see how worn the inserts are.
I replaced the shift collar & pointer a couple years ago.
Frickin' Cool Aby. Don't forget to lube the new one and the end of the shift lever. Don't ask me why I'm sayin' this.
hooler1
07-21-2013 11:42 PM
clinkfield
01-21-2012 04:14 AM
66_in_ky
12-25-2008 08:28 PM
muddy udders
01-21-2007 10:08 PM
