Questions about 2005 to 2008 trans modification
I have a 2005 Ford 6.0 CC 3/4T 4X4, 52,000 miles. I want to modify the transmission to use the 2008 oil pan and filter.
#1 When I do the exchange, how much transmission fluid should I need? No need to buy a bunch extra that I won't need.
#2 Do you just use the gasket to seal the new pan, use a silicone sealant without a gasket, or?
#3A When I put the new pan and filter on, I'd like to change to synthetic. What are most people using? I'm in Alaska and the truck will see -55F a couple of times a year. I will be pulling a 12,000# load behind it several times a year.
#3B In going to synthetic, I know I won't get all of the old ATF out. Should I take this modification to a tranny shop so they can flush it to get more of the old ATF out? Or, fill it with synthetic, run it a little and drain it again with another fill of synthetic, or?
Thanks for the help,
Bill
Bill
When you take the old one out and put it next to the new filter, you'll see why you are doing it. No comparison...
OP: You reuse the old gasket, no sealant needed or wanted. Be sure to get the neck seal out from the old filter -- it can get stuck up in there when you pull the old filter out...
What a terrific and cheap upgrade
why, ahem yes, somebody did
Here ya' go: skip pages 3-6 as it goes well off topic...
https://www.ford-trucks.com/forums/1...ns-filter.html
I am mobile so I can't post a link right now.do a search for 2008 transmission pan.... I did a write up on it a few months ago including part numbers.
mine took 9 quarts, Amsoil ATF works too, despite what some people may think
This is the OP,
Thanks for the info. I've ordered three gal of Maxlife, I'll do the change in a couple of weeks.
The only question that someone brought up that wasn't answered was asking if the original Ford transmission fill was a synthetic product? I did call Valvoline to confirm their product wouldn't have any problem mixing with Ford's original fill so I'm good to go.
Bill
Bill
This is the OP,
Bill
Bill
Posted the same information yesterday in another thread so I will share it here. The FTE link has all the P/N's as well.
https://www.ford-trucks.com/forums/8...n-updates.html
See TSB 08-26-4
Bill
Bill
TSB 08-26-4
01/05/09
5R110W COLD WEATHER TRANSMISSION FAILURE
IN VEHICLES BUILT BETWEEN 5/18/2007 AND
11/1/2008
FORD:
2008-2009 E-Series, F-Super Duty, Low Cab Forward
ISSUE
Some 2008-2009 F-Super Du
