5R110W tranny pan updates
Well I got the parts together for the ’08 tranny pan swap tackling the task this evening. I’m really glad to have found the drained fluid just as clean looking as the new fluid out the bottle. I didn’t find anything in the bottom of the pan that would have caused me great concern. The most shocking part was the plug magnet that has collected 104K miles of fine metal particles. I cleaned the magnet off and installed it on the new ’08 pan. I took the time to replace the smaller in-line by-pass filter in the front of the truck. After a short test ride to confirm no leaks or drivability concerns I’m glad she’s ready for another 100K plus of smooth shifting and hard pulling.
There is definitely a difference in the Mag-Hytec pans... there must also be a difference in the OEM pans.
2003-2007 pan (Mag-Hytec Part # F5R110) Note: Only the bottom fin is shorter than the rest. Also, the fins end approximately 1.5" from the edge of the pan (left side of pic).
2008-2009 pan (Mag-Hytec Part # F5R110W) Note: The bottom two fins are shorter than the rest. The fins appear to end at the edge of the pan (approximately 1.5" longer than the pan above).
<?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:shapetype id=_x0000_t75 stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" oreferrelative="t" o:spt="75" coordsize="21600,21600"> <v:stroke joinstyle="miter"></v:stroke><v:formulas><v:f eqn="if lineDrawn pixelLineWidth 0"></v:f><v:f eqn="sum @0 1 0"></v:f><v:f eqn="sum 0 0 @1"></v:f><v:f eqn="prod @2 1 2"></v:f><v:f eqn="prod @3 21600 pixelWidth"></v:f><v:f eqn="prod @3 21600 pixelHeight"></v:f><v:f eqn="sum @0 0 1"></v:f><v:f eqn="prod @6 1 2"></v:f><v:f eqn="prod @7 21600 pixelWidth"></v:f><v:f eqn="sum @8 21600 0"></v:f><v:f eqn="prod @7 21600 pixelHeight"></v:f><v:f eqn="sum @10 21600 0"></v:f></v:formulas><vath o:connecttype="rect" gradientshapeok="t" o:extrusionok="f"></vath><?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o:lock aspectratio="t" v:ext="edit"></o:lock></v:shapetype><v:shape id=_x0000_i1025 style="WIDTH: 603.75pt; HEIGHT: 412.5pt" o:button="t" href="javascript:window.close()" alt="#F5R110 - Click Image to Close" type="#_x0000_t75"><v:imagedata o:href="http://www.mag-hytec.com/store/images/Ford%205R110.jpg" src="file:///C:\DOCUME~1\ANDREW~1\LOCALS~1\Temp\msohtml1\01\cli p_image001.jpg"></v:imagedata></v:shape>
<v:shapetype id=_x0000_t75 stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" oreferrelative="t" o:spt="75" coordsize="21600,21600"> <v:stroke joinstyle="miter"></v:stroke><v:formulas><v:f eqn="if lineDrawn pixelLineWidth 0"></v:f><v:f eqn="sum @0 1 0"></v:f><v:f eqn="sum 0 0 @1"></v:f><v:f eqn="prod @2 1 2"></v:f><v:f eqn="prod @3 21600 pixelWidth"></v:f><v:f eqn="prod @3 21600 pixelHeight"></v:f><v:f eqn="sum @0 0 1"></v:f><v:f eqn="prod @6 1 2"></v:f><v:f eqn="prod @7 21600 pixelWidth"></v:f><v:f eqn="sum @8 21600 0"></v:f><v:f eqn="prod @7 21600 pixelHeight"></v:f><v:f eqn="sum @10 21600 0"></v:f></v:formulas><vath o:connecttype="rect" gradientshapeok="t" o:extrusionok="f"></vath><o:lock aspectratio="t" v:ext="edit"></o:lock></v:shapetype><v:shape id=_x0000_i1025 style="WIDTH: 603.75pt; HEIGHT: 412.5pt" o:button="t" href="javascript:window.close()" alt="#F5R110 - Click Image to Close" type="#_x0000_t75"><v:imagedata o:href="http://www.mag-hytec.com/store/images/Ford%205R110.jpg" src="file:///C:\DOCUME~1\ANDREW~1\LOCALS~1\Temp\msohtml1\01\cli p_image001.jpg"></v:imagedata></v:shape>
Yea visually next to each other the OEM pans aren't that different. Since the new in-pan filter is taller the pan is a tad deeper. The case of Mercon SP cost me $50, this whole upgrade cost me $150+ the in-line filter. I'm glad to know that the magnet is doing it's job and now I'm ready for another 100K+.
You can get it at diesel filters online (www.dieselfiltersonline.com). I was able to get it for less than what the dealer wanted.
