door pull seals
I'm sure you're talking about the dust covers that fit behind the door pull. LMC trucks has 'em. Check out the door handle dust cover (Truck Parts and Truck Accessories)
What you may want are the door weather strips .. that attach to the door shell itself.
Door panels are interior upholstered trim panels.
Door pulls are the cups that fit inside the armrests, that your place your fingers in to pull the door closed.
On XLT's & Lariats, there are straps that are located on the trim panels above the armrests that you pull to close the door.
Carpenter has the best quality weather strips.
Here's a coupla parts catalog pics that I couldn't post on t'other site where you also asked this question.
Notice 20530 in the right pic. This is a piece of the door weather strip that wraps around the circumference of the door
I assume this is an F100/350, but you are describing these "seals" wrong.
Since I haven't owned one a these trucks since 1988, and you've taken many apart, you knew what the OP wanted.
D4TZ-1020334-A .. Shield-Front Door Latch Remote Control Opening / Obsolete
1974/77 F100/750 / 1978/79 F100/350 & Bronco // 1974/77 F250/750 Crew Cab Rear Door / 1978/79 F250/350 Crew Cab Rear Door.
