48 ford f5 rear axel
Right, Joe. It's the Dana 70HD from a mid/late '70s or early '80s Dodge RM 400/500 based Class A motor home. Same 5 lug x 8" bolt pattern, and spring perches line up I believe within 1/8" on each side. The way it looked to me when I had mine all I'd have had to do was grind a bit off the perches on one side of each and it'd be done. I realized I wasn't getting the project done so sold the axle and my set of Alcoas to a near by F-5 guy to use under his truck. The 4.56/1 gear set teamed with the 19.5s is a nice package. I've since seen the swap made under a similar sized Studebaker M16. Below is the pic of mine. Stu
Gertie-The '49 F2
20
07-28-2012 05:55 PM
Kuskoal
10-19-2008 02:49 PM
