400ci engines; from car or truck?
Old 05-23-2015, 09:08 AM
BarnieTrk's Avatar
BarnieTrk
BarnieTrk is offline
Originally Posted by BuzzLOL
. Yeah, obviously the casting number on the crank isn't the "only" way to tell if it's a 400... if the pistons go up and down 4", then it's a 400...
. And, of course, the top radiator hose has to go down into the block, not into the front of the intake manifold like a 221 - 351 Windsor...
Yeah, there is no question on whether or not it is a 221-351W engine....it is NOT.
BarnieTrk
Old 05-28-2015, 08:21 AM
BarnieTrk's Avatar
BarnieTrk
Fellas,
UPDATE:
I removed the spark plug wires, heater & radiator hoses, fan and spark plugs. This engine still has the power steering pump and alternator (with their belts) secured to it. I also noticed that it also has an Edelbrock 400 intake manifold on it.
In an effort to determine if this is truly a 400 engine, I decided to check the piston stroke. I proceeded to turn the engine over to ensure get a piston to the BDC, however, when I put a socket wrench on the dampener bolt, it would not turn over. I squirted some fuel oil into the sparkplug holes and will let it soak in on the pistons for a few days....and hopefully will free up the pistons.
I'm not too sure about determining the stroke from the spark plug hole anyway, because it is above the top of the block deck and will add to this measurement - so what should be my total measurement taken from the spark plug hole?
I may be further ahead to flip the engine over, remove the oil pan and check the crankshaft for a casting ID........
BarnieTrk
Old 05-28-2015, 09:02 AM
shaker666's Avatar
shaker666
shaker666 is offline
You can easily see the block casting ID with the engine fully assembled and even installed in a vehicle. If it starts with D7TE or D8AE it's one of the reinforced blocks. What you want to look for in addition to the ID code is the date code. If the date code is 7C02 or earlier, it might be one of the bad castings from the Michigan Casting Center.
Unfortunately, the only way I would be able to tell if it's a 400 is the crank marking or inspecting the stroke if the heads were removed.
Old 06-02-2015, 09:31 PM
BarnieTrk's Avatar
BarnieTrk
Shaker666,
Thanks for your reply!
JUST WHERE IS the block casting ID located on the block?
I have located the CF (Cleveland Foundry) cast into the top of the block, behind the intake, just to the LEFT of the oil sending unit. There is also an oval FORD cast inbetween the CF and the oil sending unit. Also on the top of the block, on the RIGHT side of the oil sending unit, there is a machined flat where I located a stamped code ' Z HA 2373 ' but I don't know what that is trying to tell me.
Do you have any clues to help with the the stamped code?
BarnieTrk
Old 06-03-2015, 03:51 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
There should be a casting ID code on the pass side of the block down by the starter motor/exhaust manifold.
Old 06-03-2015, 08:46 PM
artscott61's Avatar
artscott61
artscott61 is offline
do they make a double sump pan for the 400 ?
Last edited by artscott61; 06-03-2015 at 08:49 PM. Reason: did not think it posted
Old 06-03-2015, 08:48 PM
artscott61's Avatar
artscott61
Do they make a double sump pan for the 400 like they do for the 302's ? I probably will sell mine that is in my f-100 55.
Old 06-03-2015, 09:05 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
I've never seen one...
Old 06-04-2015, 07:56 PM
BarnieTrk's Avatar
BarnieTrk
Ok,,,,Yep, sure enough - under the crud I found it.
Just above where the starter would be is: D7TE A3B
Although that casting number isn't on the list found at:
M-Block 351M/400 Parts Reference
I would think it would be safe to say that this casting number would indicate that this block was manufactured between 1977-1982. Although this still doesn't give me a specific year of manufacture, if I combine this information with the previously mentioned, Cleveland Foundry 'CF' casting mark from the top/rear of the block , the list information indicates it came out of a truck and lastly that it DOES HAVE THE REINFORCED MAIN WEBBING. All good news!
Thanks for all the help, Guys!!
BarnieTrk
Old 06-04-2015, 08:22 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Yes, a D7TE block is what you'd ideally have for a truck.
Casting date, I forget exactly where that's at... but look at Bubba's site, it's in there someplace....
Old 06-04-2015, 08:28 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
OK, so, you have an A3B, Bubba shows an A3A... that entire three-character code is just a revision suffix, I'd guess he never became aware of such a revision.
The D7 means the block was DESIGNED IN 1977; some parts they've designed have remained in use unchanged for several several years (even decades). But this has absolutely nothing to do with when the particular block was actually cast...
Bubba's site is good, read that and learn that stuff.
Here's another site I send people to on learning the FoMoCo parts numbering scheme:
Classic Mustang Part Number Decoding Guide
Old 06-04-2015, 10:30 PM
Old Brown Truck's Avatar
Old Brown Truck
Old Brown Truck is offline
As far as 400's being in cars, my father had a 78 Lincoln Mk V with a 400 in it.
cardude
21
09-21-2009 03:00 PM
Eagle460
54
07-08-2008 10:18 PM
swamphog
10-30-2006 01:02 PM
scionti 94
General Automotive Discussion
11-25-2004 01:35 AM
hell on wheels
15
02-24-2004 03:58 AM
Quick Reply: 400ci engines; from car or truck?
