Proper Engine hoisting
Have have an 2003 excursion... I pulled my engine to do the timing cover... I've done this same job one other time and I have issues with the chains on the engine hoist tearing up the cow above the engine... I tried several different orientations of the chains hooking them to the factory lift hooks attached to the heads... If I put the chains too tight they bend the hooks inwards and it makes me pretty nervous.. Is there a better place to mount the hoist chains to let me get the engine back in there more easily?
Just did the one in my 350 and all I did was put the chains in tight, let them bend a bit, (I was told they would) then re-tightened the chains and picked it out. Shortened the chain on the cherry picker quite a bit as well. Once I got it out I added a swivel and boy does that help. Personally I had a hell of a time making a make-shift stand so I could transfer it from the cherry picker to the engine stand!
murraydav
Modular V8 (4.6L, 5.4L)
07-15-2008 10:30 AM
Jrock909
04-09-2007 09:24 PM
