starter makes a whine after cranking.
I'm pretty sure it's the original starter, auto zone sells them for 130 so I think I'll buy a new one, thanks for the reply.
Well, I put the new starter in and I'm getting the same thing, I wonder if the ignition could be bad causing it to spin longer than it should? that's why I hear the zzzzzzzzzzzzz sound?
from what I could see the fly wheel looks fine, sounds like the starter is spinning for a second or two after it cranks. just replaced the alternator, batteries with in the last 6 months. I'm seeing 13.45 to almost 14 volts..I can hear the starter engage the fly wheel before it cranks, then afterwards its like the gear is pulled back off the flywheel and free spinning for a second or two.. both starters sound identical.. it only makes the spinning sound after it is cranked..it starts fine, just makes the weird spinning noise for a second or two afterwards.
that's what im beginning to think, the ignition switch has to be wiggled in order for the dinging to stop after I remove the key and try to exit the vehicle, so I know its not working correctly...
Aridecommando
23
12-16-2015 12:34 PM
pit_of_pity
12-15-2010 07:26 AM
