HELP! alternator, batteries...relay???
early 99 f350 7.3 4x4 after recieving jump from AAA (ford f-250) thank god.
readout indicated no charge from alternator...replace alternator (duralast gold) same problem...find ring terminal connection to alternator split...replace, fires up and seems to charge up...went to Les Scwab hav ignition system check says alternator not charging...(but it is)...park after driving for 2 days batteries dead...batteries checked...they r good recharge(Interstate MTP-65's)..they immeadiatley drain and truck dies...have i some how broken the 2 wires to plug in to alternator...they look good...Is there some type of relay in the system i am unaware of? Any and all help would be much appreciated.
Thank u in advance
Thank u in advance
Check to see if both big terminals on the glow plug relay are hot. One should be and one should not be when the truck is turned off. Same for Air intake heater relay. Either would cause all your problems.
The only other thing I have heard of is was a fusible link blowing and causing a battery light to stay on all the time, even with new alternator. You did not say that so I did not mention it at first.
Received 3,107 Likes
on
if the fusable link for the charging circuit is bad, the alternator will show output and test good, but the batteries will not see the charge.
also if the diodes in the alternator are bad, the batteries will discharge overnight.
the alternator will test good even if the diodes are bad, because they stores check for output, not diode condition
to test for bad diodes, feel the alternator on a cold engine. if it is warm, the alternator needs replacing. .
on
The Sensing & Switching Circuit controls the Alternator Output (on/off). Fuse #6 in the under hood junction box (5 Amp). connects the circuit to the instrument cluster.
Check for continuity from Fuse #7 (LG/R) to the Alternator Plug. If there is no continuity, I have found several:
Chafed wires at the valve cover plug.
Corrosion on the bottom of the Junction Box
And defective Pins on the Alternator Plug.
Hope this helps.
Tom
Hope this helps.
Tom
it was Fuse #6 under hood, looked good but failed test...alternator putting out 14.40 v.....THANK YOU....the original alternator had some plastic piece break inside causing short...but was very frustrating buying new alternator from Autozone Duralast Gold supposedly triple tested...was bad.
bought lifetime alternator from Napa...guy looked at me weird when i had him test before i left store....Thanx for all the help!
zippylaredo
08-28-2011 06:37 PM
Nyxlee
01-26-2011 09:07 AM
02GrayPowerStroke
02-02-2010 08:56 AM
