charging issues
Old Nov 25, 2003 | 10:14 PM
JRM99's Avatar
JRM99
Angry charging issues
I have a charging issue with a '99 F-250 Diesel. The truck went completly dead and would not start. The battery's were charged and tested as in good condition. The alternator was also tested while running and tested @ 12.5 volts. I need to know if I have a bad batterry or a bad alternator. If I am not mistaken the alternator should be running @14.5 volts charging up the battery's. I am not sure if I have a short causing this or the alternator is bad. If there was a short then I would not have a voltage reading at the alternator, right? Where should I start?
Old Nov 26, 2003 | 01:43 AM
HoseDog's Avatar
HoseDog
You're probably just reading battery voltage at the alternator if it's only 12.5. You are right to expect about 14.5 while it is running. If you did have a "short", or have used jumper cables without due caution, you may have blown the diodes out of the alternator.
Old Nov 26, 2003 | 06:46 AM
powerstroker250's Avatar
powerstroker250
What HoseDog said.
Old Nov 26, 2003 | 11:27 AM
bcmmdl's Avatar
bcmmdl
I just had a similar situation, but the truck started and ran fine. My batteries were still fully charged but alternator was dead(same reading as yours). This was funny because I drove over 200 miles with the check light on, at night, in the rain. I replaced the alternator and it set me back $170.00.
