Auxiliary lights placement options
Old 04-23-2015, 03:36 PM
Jarryd's Avatar
Jarryd
Jarryd is offline
I found a couple kits on eBay in addition to the lmc one that claim to use 14 gauge wire and plug into the factory harness so no wire cutting is necessary. I hate cutting factory wires so I may go that route.
Old 04-23-2015, 04:00 PM
krooser's Avatar
krooser
krooser is offline
just remember to be courteous and dim those extra bright lights when approaching oncoming vehicles. I can tell you first hand that as you age (maybe 50+) your eyes don't appreciate those blinding lights coming at you… and make sure they are aimed correctly. No sense doing all that work to shine one light at mars and the other at a gopher hole...
Old 04-23-2015, 06:23 PM
Crewcabber's Avatar
Crewcabber
Crewcabber is offline
14 gauge seems light to me. Use two 30 amp relays with socket and pig tail some 10 gauge to power them and to the headlights and use your 14 gauge to trigger.
Old 04-24-2015, 05:43 AM
ng19delta's Avatar
ng19delta
ng19delta is offline
I always loved t he headlights in my original 88 bricknose: They provided the BEST lighting of almost any vehicle I've owned! And my favorite story is about when i was driving in Knoxville, Tn. many years back, about 2am, rolling west on 40, in the middle of what seemed like six lanes wide, and this guy comes off the ramp, cuts across ALL these OPEN lanes of traffic to pull his '50s pickup directly in front of me(the ONLY vehicle in the area) doing 50! I hit the brakes and the high beams- it looked like God was sitting in the cab with him it got so bright! There was a tractor-trailer going the opposite way who commented on the CB about the guy lighting up the pickup on 40... I explained WHY I had lit him up(cutting across all those nice, empty lanes to cut me off!) and he got the picture, and laughed... I backed off, and went around him... Reminded me of "Close Encounters of the Third Kind"... lol...
Those headlights should clean up, and with better bulbs & relays, should be just fine... Even my current bricknose, with slightly beat up headlights gives a good showing... FAR better than my 2003 Police Interceptor! I can ride around all night with the high beams on, and no one notices! Nor do they give very good illumination! Even on high beam, they are barely better than the low beams on my bricknose: been that way since I bought the car, and no amount of adjustment improves them...
Scott
Old 04-24-2015, 06:20 AM
Ford SD's Avatar
Ford SD
Ford SD is offline
Did you do the relays on your '88? I've checked the lenses and they're actually pretty darn clear. I think it's a combination of tired lights and poor current due to the factory wiring setup. If someone has a link to the eBay or LMC kit can you post it? Not sure if I'm going that route or just cutting factory wires to put relays in.
Old 04-24-2015, 07:04 AM
Jarryd's Avatar
Jarryd
Jarryd is offline
http://m.ebay.com/itm/120897726997?nav=SEARCH
http://m.ebay.com/itm/191518369271?nav=SEARCH
Here are links to a couple of the kits. one says you can run higher wattage bulbs but that would likely melt the housing.
The lmc on its on their site. I can't tell much about it because their site sucks.
My question now, is if doing this would be better than doing LED conversion or of it would help the LEDs.
Old 04-24-2015, 12:45 PM
firegod33's Avatar
firegod33
firegod33 is offline
I haven't seen any LED conversions, or even projectors for the bricknose trucks. I've seen them for the bullnose and obs.
Old 04-24-2015, 01:15 PM
Jarryd's Avatar
Jarryd
Jarryd is offline
I was talking about the LED bulbs that replace the halogens.
Old 04-24-2015, 10:43 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Originally Posted by Jarryd
That LMC harness is only $30. Has anyone installed it and can comment on ease of install vs buying the relays, fuse holder, and wire to make your own? If it's just plug and play vs cutting factory wires, it may be worth it.
I've got the LMC harness on my '70 and '73. Easy to install but the length of the harness is barely enough to span between the headlights. Also, the relay plugs are not your standard plugs - they are a specific off-brand automotive relay.
To fabricate, you'll need 14g wire in at least four colors. two relays, two headlight plugs, eyelet terminals for grounds, two male spade terminals for the relay on/off signals (hi/lo), and female spade terminals for the relays unless you opt for relay plugs.
The cost difference btwn the LMC and a home-fabbed harness is minimal. I got them as a matter of convenience. However, buy the components in bulk, like from Delcity.net, and the savings increases.
Old 04-25-2015, 07:04 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
I would stay away from LMC. Cheap parts and like said BARELY enough wire to fit.
I got mine through RJM but he is now out of business.
If you do a search on here there was another company that makes them too. Those 2 on eBay look cheap
Old 04-25-2015, 11:38 AM
Evan_P's Avatar
Evan_P
Evan_P is offline
Old 04-25-2015, 02:27 PM
HIO Silver's Avatar
HIO Silver
Originally Posted by Evan_P
True. That harness can be built for around $40.. retail.
  #28
Old 04-25-2015, 05:10 PM
Diesel_Brad
That is the one I was thinking of. Money WELL spent.
The only thing i don't get is why have a ground at each headlight, when ONE near the power supply is more than enough
tmkemp79
02-13-2012 11:48 PM
DIYiT
General Automotive Discussion
04-12-2011 12:54 AM
jlstorm
1999 to 2016 Super Duty
32
01-03-2009 05:30 PM
tdister
2004 - 2008 F150
12-15-2006 06:55 PM
b1gr3d
23
03-28-2004 09:29 PM
Quick Reply: Auxiliary lights placement options
