Custom vs Canned for everyday driving.
I liked the canned SCT tunes.
I used to use the Performance and Street tunes quite a bit as a DD.
Now I use the Gearhead 8K as my DD, which I would consider a little hotter than the canned Street tune.
My PCM/TCM really liked the canned Performance tune. Excellent highway MPG and the trans shifted perfectly.
Josh
Josh
I have Matts SRL and his tow tune. Been using the tow tune. SRL shifts horrible and he has adjusted it twice.
Maybe Matt changed something?
Either way, Matt has been worthless about fixing it.
Josh
When did you purchase the SRL tune? I think mine was about this time last year. Seems there are several of us complaining about the SRL's shifting now, whereas, it didn't seem like a problem before.
Josh
Josh
Mine was the same way. I asked for this correction.... hold the shift to the last possible second, lock the convertor right away and make it so I really have to step down to get a down shift, as in nearly floor it.
Mine is shifting great after that. Also tighten the smoke control, I hate smoke!
I also have SRL, 8K tow, and unlimited tow from Gearhead. SRL shifts so bad that I can't even use it. I run the 8K tow as my DD. I also have Looney Tune from QuickTricks and I like it real well. It shifts great and the only reason I don't usually run it as my DD is because I can't seem to keep my foot off of the skinny pedal when I'm running it! LOL
Which isn't too big of deal except when you nudge the throttle to speed around a car and then Wham!
Josh
My new looney is more linear in power but doesn't seem to have the *** my old looney does.
I would probably use it more, but it makes me paranoid she has the idle ICP @ 625+ and IPR @ 25%
With the higher idle pressure it idles glass smooth though.
Josh
Mine is extremely touchy on cold oil. You can definitely tell at what RPM the IPR is set to move. It will snap your neck if you let it. Let her get warmed up a little and it pulls smooth and strong. Transmission is really happy with it too.
Josh
