Grille XXX Porn
#61
#63
#64
You need to strip the anodizing off, you need a lot of small weird shaped hammers. You need to know how to do body work. You need to know how to sand aluminum, you need to know how to polish aluminum.
And if you use a commercial polisher like I use, you need,
HUGE CAJONES!! It's scary.
So really I don't know how to help you.
#66
Before final assembly my grilles are washed and all the rouge is removed from the back. I then use Master Formula
once this id done then I assemble.
Clear coat will yellow or make them look foggy. No anodize shop close by and the one shop I used in Los Angeles did such a crappy job I never went back.
So I continue to, commercial polish, hand polish then seal.
#67
No, I use a hand polish and a sealer when I'm done with them.
Edit. And yes, you do deserve a bigger hat size.
#69
Hang in there and check back Tanner. Since the little green lamp next to his name (like in post #66) isn't lit that tells us he isn't on the forum at the moment.
#70
PM me and we can chat.
#71
Not for the squeamish. I finally assembled the ultimate front end for the 69 ford truck. Standard Cab or Ranger.
If you are on medication of any kind, go to another thread,
DO NOT PROCEED!!!
If you have clearance from a medical physician or are strong enough that when the wind gets sucked out of your lungs you won't collapse, then proceed....
Attachment 117920
Attachment 117921
ALL PARTS ARE NOS!!!!!
DO NOT PROCEED!!!
Attachment 117920
Attachment 117921
gangstakr
39
12-11-2014 07:44 PM
