Cab corner question
04-16-2015, 10:14 AM
Cab corner question
I was thinking of filling my F-6 COE rear cab corners with foam to keep debris from falling down there. Any thoughts?
04-16-2015, 10:40 AM
on
04-16-2015, 10:44 AM
I agree. Bad idea. Get yourself a shop vac and tape a small diameter tube to the hose.
04-16-2015, 11:33 AM
Did that. Just thinking of eliminating a repetitive task. Didn't think moisture would be an issue, wouldn't the space become air tight?
04-16-2015, 11:39 AM
Ford put foam in the bedsides above the wheel wells on the super duty. Look how that turned out.
04-16-2015, 12:28 PM
Quote:
Originally Posted by
Gicknordon
Ok, you win.
04-17-2015, 09:06 AM
on
Cab Corners
I was glad that someone asked this question & others had responded. I was thinking of using the foam, but wondered if it would be moisture free. Apparently it isn't. Thanks for not letting me make that mistake. psmith1951
04-17-2015, 10:13 PM
on
PO did that
My 51 cab was foamed down in the corners. My corners are rusted thru. I agree, moisture was the cause. Of course, the old girl did come from the upper Michigan and North Dakota before that.
04-18-2015, 03:47 AM
Just one of the things you learn not to do after cutting out enough rusted panels. VW even made that mistake in the 60's.
04-27-2015, 08:05 PM
Thoughts on the rubberized undercoater in a spray can for the cab corners, and what is a good sound deadener for the cab panels and roof?
Tim 79 F150
05-13-2013 10:59 AM
Broncoguy89
02-04-2013 07:25 PM
Rent-A-Racer
01-25-2005 05:55 PM
harpmatt
02-13-2000 10:01 PM
